Forum: VirtualDJ Skins
Topic: Favorite Skins?
I downloaded the Pioneer skin interface... it looks great and functions extremely well with added triggers. Does anyone else have any good skin references?
geposted Sat 14 Apr 07 @ 10:08 am
V Mix 4 video is the only one I use, The V Mix 5 have a lot of info, but it's too much for me.
I like the "CUE" version/VDJ4 is the best.
I used to use the defaul audio skin. But since the Mix Lab skin came out, that's my weapon of choice. Very professional looking and has all the functions right there.
Thank you!!!
DJ FORMAT
DJ FORMAT wrote :
Thank you!!!
DJ FORMAT
No, Thank you!!!!! :)
I actually like the tascam skin. mainly because of the loop buttons and the layout. The cue skin is cool, but when i use cue my hercules headphone select does not work.
Hercules headphone cue midi command is "headohone_crossfader", you can see this crossfader movement on the top of my skin.
CUE on deck 1 show cursor top left or CUE on deck 2 cursor top right.
Download skin link http://www.virtualdj.com/addons/skin.html?id=3196
