Forum: Old versions
Topic: Urgent Help Needed
I am at the final stage in breaking and destroying my laptop.
Before that, i decided to see if you guys here can help out.
here is the problem,
I have just bought Behinger for my VDJ 4.1, at first it was good, i could mix, hear a song thru my headphone and play the another song thru my speaker...that was good.
After a while, if i load a song, thats is more than 15mins, it will crash my laptop and shut off on its own and i have to restart it.
And when i do restart it, and click on the vdj, its says Error in the ASIO Driver.
Someone told me to download ASIO4ALL, i did and i am now using it.
The problem now is that, i cant hear my music playing on my headphone and play another thru my speaker, i dont know wot i ahve done wrong.
And another problem now is that, the sound coming from my speaker is bad, its not that smooth how it was before.
here is my soundcard setting on VDJ 4.1
Input...none
Output...singe output
Soundcard..ASIO driver
ASIO Driver...ASIO4ALL V2.
Its only work with this setting only, other setting is doesnt play/work.
If i use Asio driver....BCD2000ASIO..Its doesnt work and also i cant ASIO Configure, but can on ASIO4ALL V2.
But my Behringer still works, the only thing that doesnt work is the PFL mix with the headphone, i cant control it,if i turn it to A OR B,its play the same song...so to say,there is sound coming out of the headphone either the pfl mix is on or off, if u know wot i mean.
I need urgent help as i am djing next weekend.
geposted Sat 14 Apr 07 @ 11:43 am
i recommend you update your demo to 4.2
you need at least a 4.1 sound card to do this with two outputs
and
you need this
input :none
output: headphones
card : asio driver
ASIO: driver asio 4 all
you will need to now assign channels.
kind regards.
Simon
How do i assign the channels?
Before i was using:
input: none
output :headphones
soundcards:BCD2000
and its works,
why does it stop working?
And i only started using ASIO4ALL when the problem 'Error in ASIO sound driver' start showing up
I am now using VDJ 4.2 and it's working well.
thanks
cool hope to see you as a pro user soon :)
