Forum: Old versions
Topic: auto playlist
Thinking about buying Virtual Dj, I downloaded the trial. Q: Once songs are selected in playlist, can they upload to the next availiable deck automatically and fade in by itself? In other words auto pilot while you are away from the equipment temporarily. I'm sure it does how do I enabel this feature?
geposted Sun 15 Apr 07 @ 4:34 pm
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
are you using a trial version now? if so it can be done and is very easy
geposted Sun 15 Apr 07 @ 4:39 pm
oops clicked tab by mistake. Drag the song to the "playlist" box on the right of the screen. Sitting on the line is a little microphone. Click on the little microphone and your in auto-play. I have tried it with beat matching and setting up the breaks.
geposted Sun 15 Apr 07 @ 4:42 pm
I'm an idiot ! That was Simple, Thanks for the tip!
Later
geposted Sun 15 Apr 07 @ 8:44 pm
no Problemo you old Pirate
geposted Sun 15 Apr 07 @ 11:14 pm
