Just finding other user from singapore in this forum lol, maybe can contact n share experience while werkin with this great software.. and gigs too.:)
geposted Sun 15 Apr 07 @ 6:32 pm
You can find your country fellows on the User Map:
http://www.virtualdj.com/map/
geposted Sun 15 Apr 07 @ 8:58 pm
@DJ-ALF Cue users are not on the map. I was told there were no plans to do so in the future. So If anyone is curious I live near Chicago IL.
geposted Sun 15 Apr 07 @ 11:08 pm
Sorry to hear that, I think Cue users should be on the map :)
geposted Mon 16 Apr 07 @ 12:56 pm
Yah, i did know to use the user map thingy, but the problem is , i think apart from myself , there are only few of them registered user. hence i try to find out the others that did not appeared on the map. i do no that the cracked version of virtual dj is used by many here n i did not quite like it. anyway thanks @dj alf for the respone n have a spinning day:)
geposted Mon 16 Apr 07 @ 1:55 pm
No problem, what to say, I am the only one from Serbia on the map, could be someone else?
geposted Mon 16 Apr 07 @ 4:03 pm
hmm. where could the others be...
geposted Mon 16 Apr 07 @ 7:40 pm
