Can the herc handle scratching a tcv?
geposted Sun 15 Apr 07 @ 11:05 pm
It does support this feature but the quality is not very good. Shame though, as the Herc MK2 would be a good size midi controller when combined with TCV. Best go for the Maya or U46DJ.
geposted Sun 15 Apr 07 @ 11:54 pm
can't find em...
geposted Mon 16 Apr 07 @ 6:20 am
Here they are:
Maya 44 USB:
http://www.audiotrak.net/maya44usb.htm
ESI U46DJ:
http://www.esi-pro.com/viewProduct.php?pid=60
you can use your MK2 for samples and as midi mixer and Maya or Esi as sound card.
Maya 44 USB:
ESI U46DJ:
geposted Mon 16 Apr 07 @ 12:50 pm
I'm running the Herc MK2 with TCV's and have no problems, and my pc is by no means a work horse, only Dell Inspiron 1200 w/ 512MB of RAM and a 1.3GHz Celluron (it is a VDJ dedicated machine though)
Check out skyfl's configuration details for the Herc w/ TCV and using "ASIO 4 All" for the audio drivers as opposed to the shartty ones that come from Hercules. I had pretty poor scratch results before following his set up, now I'm in love again <3
geposted Mon 16 Apr 07 @ 7:39 pm
thanx for the linx, but both are discontinued. I know that the u46dj is out now, but you have to buy it with another software package n stuff...
I guess I could try to find a maya 44 somewhere....... ebay i guess
-------Added---------
Just looking at both the maya 44 usb, and the gigaport ag, they look AWEFULLY similar, like almost the exact same thing....
Which one is better? the gigaport i see goes (or I should say, it went) for $50 more than the maya
geposted Tue 17 Apr 07 @ 7:18 am
Look no further :))
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=STRK%3AMESE%3AIT&viewitem=&item=130101961366&rd=1&rd=1
BTW, ESI is better ;)
geposted Tue 17 Apr 07 @ 2:04 pm
awesome. cept i'm in the states.
ESI is better for what? all around, or tcv scratching?
geposted Tue 17 Apr 07 @ 5:24 pm
I think both ;)
geposted Tue 17 Apr 07 @ 7:59 pm
ESI u46dj is a mighty fine piece of equipment, definatly one of the best external cards in it's price range, especialy for heavy scratching. The delta 1010lt is better imo, but you need a pci slot for that one. I used to use my mk2 for tcv before I bought the u46dj, but as others have said it's asio drivers make heavy scratching a big annoyance. Never tried it though with the asio4all drivers, but the u46dj is just a much better soundcard;^]
geposted Tue 17 Apr 07 @ 11:27 pm
