I purchase DJ console MK2 today and I'm experiencing problems installing it in my lap top. After inserting the software a get a message saying (String IDS_TargetReq_DESC_OS was not found in string table. That's far as I get. I need help.
geposted Mon 16 Apr 07 @ 1:08 am
hello johnnie
you need to install the vista version
http://www.virtualdj.com/update.html
and the vista driver
http://www.virtualdj.com/forums/66083/Hardware_Technical_Support/Common_Device_Drivers___Updated_last_on_14_4_07.html
now it is very important that you are logged in as an administrator during the install.
by default in vista all acounts are set to power user
so you will need to go to control pannel > user acounts > manage user acounts
on this list find your acount and press properties
click on the group membership tab
here you will see users group and admin group.
join your self to the admin group press ok
close these windows.
Restart and run the installer for the drivers
once the console is installed install virtual dj.
Hope that helps.
Hope that helps.
geposted Mon 16 Apr 07 @ 1:10 pm
Honestly, Virtual dj is getting wack, they now don't have an answer to this questions, i've been using this software for about 2 years now, and this Retards now can't help people like me that spent 300 dlls on a software to reinstall it in our computer, I suggest we get our money back. go with serato instead. this software SUCKS!!!!
geposted Mon 26 Jan 09 @ 11:30 pm
yep that will get people running to help you, even if you had posted a help topic...
geposted Tue 27 Jan 09 @ 2:46 am
What are you talking about?? I see no questions from you about problems???
geposted Tue 27 Jan 09 @ 4:22 pm
Elaborate more abt ur problem?
geposted Tue 27 Jan 09 @ 4:24 pm
If you're talking about the problem above, SKYFXL answered it already with ease since April 2007.
Now if you have any other issues aside from this topic I suggest you should start a new one.
Having COL and looking for a solution without knowing your problem is next to impossible, it's like a retard (like yourself) crying out for milk where what he really want is piece of fried chicken. Thus, having used the software after 2 retard years now you want your money back... are you well?
Go consult to a doctor man, I think your brain needs overhauling...
geposted Wed 28 Jan 09 @ 1:30 am
dude has a point, the links dont work!
rubbish, glad i didnt spend any money here. my vista doesnt intsall either, so what chioce am i left with?
geposted Sun 22 Mar 09 @ 3:43 pm
if you looked at it properly the links are two years old, and are you using a trial version...
geposted Sun 22 Mar 09 @ 8:09 pm
im not going to buy anything that doesnt even get past the trial stage, good site!
instead of mugging people off, you should concentrate on your customer service!
geposted Tue 31 Mar 09 @ 5:13 pm
Well since you seem to have issues:
Download the lastest trial version here:
http://www.virtualdj.com/download/trial.html
Install. If using Vista and you run into issues, you can try disabling UAC and seeing if that works for you.
Alternatively you can complain without asking for any help or giving any information, which will get you very far indeed ;)
With relation to the original post, the link for the software update has changed and is now:
http://www.virtualdj.com/download/updates.html
But obviously will only work if you have a registered version, not a trial or cracked version.
The Hercules update is, well, available from the Hercules website:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1
As far as customer service goes, no-one who has posted here works for Atomix - they are all users. If you have an actual question or issue, please post it or contact support!
geposted Wed 01 Apr 09 @ 3:06 am
hi.
I jst bought a new pioneer DDJ WEGO mixtable. But I can't listen to one song in the speakers and one son in my headphones.. can you help me?
geposted Thu 17 Jan 13 @ 8:44 am
Please start a new thread.
This thread is irrelevant to your question (not to mention 5 years old)
Topic Locked
Topic Locked
geposted Fri 18 Jan 13 @ 12:13 am
