I need deadly Real Volume Indicator for each deck. Which indicates the real-time volume (coming in) from the deck Relative to the Vertical Fader. The Current light bar beside the Vertical fader is useless.
Better, if there is peak volume light indicator like prof dj gear or Winamp's analyser or Cool Edit pro.
In addition, best if there is a Master Volume light bar.
Related topics :
http://www.virtualdj.com/forums/41442/Skins/Advanced_Default_(by_djjb)_-_pls_add__Actual_Sound_Level_of_Vertical_Fader_.html?highlight=rprado
http://www.virtualdj.com/forums/67595/Skins/djjb_Advanced_default_for_VDJ_4_(2007_03_28f).html?highlight=rprado
Thanks
rprado
P.S. You may ask me why I don't use an External Mixer which should already has those light bars.
There are many reasons:
One reason is : I use Tablet PC and VDJ with HDJC in the living room (on the piano), lack of space is the first reason.
Another more important reason is : I record my mix from Hard Disk of my Tablet PC via VDJ with HDJC (inverted pitch & volume : Fader as Volume fader) back to the Hard Disk. I think this is sort of DDD recording which has very little loss in sound quality I guess.
Related topics :
Thanks
rprado
geposted Mon 16 Apr 07 @ 11:10 am
