Forum: VirtualDJ Plugins
Topic: How do I install sonique and petes plugins freeframe
docPRO InfinityMember since 2020
They don't expand or auto install like the other plugins. What do I do with the folder after extracting?
geposted Tue 17 Apr 07 @ 2:36 am
The sonique folder you can extract to anywhere, and then within VDJ you (on the video effects list -> sonique) you just browse for the folder.
The pete's plugins need to be copied to C:\program files\virtualDJ\plugins\videoeffect
geposted Tue 17 Apr 07 @ 4:00 am
Ok, did the pete thingy. The program can't find the sonique tho. It doesn't show in the video effects list. Should it be in a special folder after extracting?
geposted Tue 17 Apr 07 @ 5:42 am
If you click on the effects button on the vdj main screen and then choose "video effects", Sonique isn't there as an option?
geposted Tue 17 Apr 07 @ 12:47 pm
No, but I only have sonique on my desktop, should it at least be in the VDJ folder somewhere?
geposted Tue 17 Apr 07 @ 7:03 pm
Program files>virtualdj>plugins>videoeffects.
geposted Tue 17 Apr 07 @ 11:01 pm
