In the default cue/vdj skin you can click on either of the video preview windows and the video crossfader will fade over to the picture you click on over about 2 seconds (nice and smooth too!)
So the question is, can i set a shortcut to do this?
I know you can activate the video transiton with a shortcut but that doesn't fade all the way until you stop the song you were playing. Also i know you can make the crossfader jump to a certain position and also do relative commands like -150, but that always looks jumpy and you have to hold down the key to make it fade all the way across.
Any thoughts, this would be sooo good if you can!
(I've got a DAC-3 which has shortcuts for this kind of thing, but the steps that the crossfader jumps in makes it look a bit 80s style)
geposted Tue 17 Apr 07 @ 2:05 pm
