Forum: Old versions
Topic: Loaded wrong skin
Hi,
i accidently installed the DAC 3 skin on my computer that has a higher resolution than my screen,
the problem now is that i only have part of it on my screen and i can 't see the configure tab so that i can change it , any help as how to get rid of this skin please, thanks.
geposted Tue 17 Apr 07 @ 11:17 pm
cstollPRO InfinityMember since 2004
Hit CTRL+ALT+S to open the config dialog.
geposted Wed 18 Apr 07 @ 12:05 am
Hi ,
i tried that , it doesn't work .
geposted Wed 18 Apr 07 @ 12:35 am
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
move the mouse around, if at anytime you see the four way arrow, that means you can move the skin. you might be able to move it enough to fid the config button, I know its not much but you never know.
geposted Wed 18 Apr 07 @ 12:43 am
vinny1234 wrote :
Hi ,
then at some time you must have clicked the check box to 'ignore' the keyboard short cuts.
Do this then - go delete the skin's .zip file. This will force VDJ to use one of the default skins.
The zip file will be found in the C:\\Program Files\\VirtualDJ\\Skins folder -- and the one you want to delete is the one that says DAC3 at the beginning of it.
geposted Wed 18 Apr 07 @ 1:07 am
Thanks CS, all sorted now .
geposted Wed 18 Apr 07 @ 1:24 am
glad to help --!
geposted Wed 18 Apr 07 @ 1:26 am
