can i back up my downloaded file to a cd.
how many times can i install this software
i downland the pc and mac versions. im using a pc but plan on buy a mac within 2 months.
i hope i don't have to paid for it again.
can you give me some feed back.
geposted Wed 18 Apr 07 @ 12:19 am
you have unlimited installs , if say your computer crashes you dont need to wory.
you are licenced to use two computers at once.
you may download it again here
http://www.virtualdj.com/update.html
but backing up is a very sensible thing to do aslo :)
geposted Wed 18 Apr 07 @ 12:42 pm
thanks
geposted Wed 18 Apr 07 @ 2:21 pm
Skyfxl: How exactly would you back up the files/ put it on a CD. I have yet to do this. :/
geposted Wed 18 Apr 07 @ 3:04 pm
When you download install file, simple record it on a cd/dvd, you can put inside txt file with your serial and that's it. Simple. If you need to backup your database, backup your Virtual Dj database.xml file on a cd too.
geposted Wed 18 Apr 07 @ 3:22 pm
or an external hd or , memory stick will suffice aslo.
geposted Wed 18 Apr 07 @ 3:23 pm
Yea..........ok, the only problem is I'm a lil on the "slow side" today and might need this explained step by step, just to refresh my memory. ;)
Thanx Skyfxl and DJ-ALE
geposted Wed 18 Apr 07 @ 8:26 pm
I'm on the "slow side" everyday, so don't sweat it. I'm waiting for the explanation, also.
geposted Wed 18 Apr 07 @ 8:54 pm
I use a USB jump drive and simply put the install file onto it, then I put all my skins, my backup database, and a word document that has my license number. Just drag these files to the drive.
geposted Wed 18 Apr 07 @ 10:11 pm
