Ok, the bottom line is I have a laptop with a 1440x900 resolution display.
There are no skins that i can see in this res.
I've tried the image resizing tool and it works well, but not well enough and i'm not clever or patient enought to adjust it manually like it says in the resizer instructions.
Does anyone want to give me a price for not making me a skin, but resizing a couple of existing skins for me?
I like to use the VDJ default basic, full & video skins or the Numark equivalent.
Any offers or advice?
Gary
Gary
geposted Wed 18 Apr 07 @ 10:56 pm
Try this tool, http://www.virtualdj.com/addons/download.html?addon_id=1826
geposted Wed 18 Apr 07 @ 11:42 pm
Thanks for that TearEmUp, but i did say i'd tried that lol
It worked as far as the skin did change size, but the buttons were not aligned properly.
I am using vista though, maybe it won't work with vista?
Gary
Gary
geposted Wed 18 Apr 07 @ 11:59 pm
sorry Gary I just read the first line and thought it was a double post....duh to me...lol
geposted Thu 19 Apr 07 @ 12:03 am
No worries mate, just make me a skin 1440x900 and i'll forgive you :)
geposted Thu 19 Apr 07 @ 12:09 am
I have not tried making skins, I dont think it would suite my skillset
geposted Thu 19 Apr 07 @ 2:19 am
I use the same resolution but just click the maximise button to stretch the skin to fit. Is it really that bad?
geposted Thu 19 Apr 07 @ 2:26 am
It is when you use vista. It doesn't just stretch, it actually changes the screen resolution settings, and if you are playing a video out live it will temporarily interfere with the 2nd output of the video card.
Its ok in XP, but i use vista on my laptop for work.
Gary
Gary
geposted Thu 19 Apr 07 @ 2:41 am
if you go to the skins forum you will see there is a new service about to be started if it has'nt already begun, as far as i can tell with having a quick look it is a bespoke skin service you request what you would like and they will tailorit to your needs for a price how much i'm not sure and you be in safe hands this service is only supplied by two of the best in the business they make most of the skins anyway messrs format &mykel find their site at http://skinmaster.co.uk ...Tayla
geposted Thu 19 Apr 07 @ 10:12 am
Cheers tayla,
I didn't even realise there was a skin forum!!! I hadn't worked that far down the forum menu page!
I'm surprised one of the guys didn't move the post to the skin forum and let me know.
Well it looks like i'm all sorted then, just a case of waiting for these guys to get their business up and running :)
Thanks for the info.
Gary
Gary
geposted Thu 19 Apr 07 @ 1:28 pm
no probs...Tayla
geposted Thu 19 Apr 07 @ 6:09 pm
