simple question... I have been using the Vmix skin and Vdj for the past five weeks and have been very pleased for the most part. A couple questions.
One is ...I have three total video windows open, two to preview each channel and then the main. Yet when I close and reopen the VDJ , only one video window opens on the left player , I then have to click on video/ loops tab to get it to show the window. I know this is trivial but if you can help me to open it the way it closed I would appreciate. (I am using the 8th tab under the player from left to right, which gives me some start stop and cue control.
Two, I have noticed that when I use the Key changer, that if I go over 1 semi tone, it has a wobble effect and I have just started using the pitch, but that alters the tempo.
thanks and the more I use the program and get help... the better I feel about the 295.00 I spent.
I am waiting on Perns updated DAC2 mapper. that will allow me to force fade , thanks. Michael aka, DJ before dirt (since 1978)
geposted Wed 18 Apr 07 @ 11:04 pm
