In the middle of a set try to adjust bass, etc the song cuts out for a sec or so then comes right back in. Software problem? Controller? Computer?
geposted Thu 19 Apr 07 @ 9:08 pm
Please add your system specs including video card as well as the processes running while you are running VDJ.
geposted Fri 20 Apr 07 @ 10:13 am
Thanks for your concern, hope this is all that you need. I know I have a slow computer but didnt know exactly if that was it or not. I only run VDJ when I am mixing...
OS Name Microsoft Windows XP Home Edition
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer Dell Computer Corporation
System Model Dimension 4550
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 7 GenuineIntel ~2392 Mhz
BIOS Version/Date Dell Computer Corporation A04, 1/20/2003
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
Total Physical Memory 256.00 MB
Available Physical Memory 37.61 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 703.11 MB
Page File C:\pagefile.sys
Name USB Audio Device
Manufacturer (Generic USB Audio)
Status OK
PNP Device ID USB\VID_06F8&PID_B100&MI_01\6&1627C10D&0&0001
Driver c:\windows\system32\drivers\usbaudio.sys (5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), 57.88 KB (59,264 bytes), 4/7/2007 7:09 PM)
Name Hercules DJ Console Mk2 MIDI
Manufacturer Hercules Technologies
Status OK
PNP Device ID USB\VID_06F8&PID_B100&MI_04\6&1627C10D&0&0004
Driver c:\windows\system32\drivers\hdjmidi.sys (3.100, 38.50 KB (39,424 bytes), 4/7/2007 7:06 PM)
Name Unimodem Half-Duplex Audio Device
Status OK
PNP Device ID MODEMWAVE\0\{4041B9C4-C4F5-4F3B-A0E4-5434AA1E2EFB}
Driver c:\windows\system32\drivers\modemcsa.sys (5.1.2600.0 (xpclient.010817-1148), 15.75 KB (16,128 bytes), 2/18/2003 4:20 AM)
Name SoundMAX Integrated Digital Audio
Manufacturer Analog Devices, Inc.
Status OK
PNP Device ID PCI\VEN_8086&DEV_24C5&SUBSYS_01421028&REV_01\3&172E68DD&0&FD
I/O Port 0x0000D800-0x0000D8FF
I/O Port 0x0000DC40-0x0000DC7F
Memory Address 0xFE300400-0xFE3005FF
Memory Address 0xFE300000-0xFE3000FF
IRQ Channel IRQ 17
Driver c:\windows\system32\drivers\smwdm.sys (5.12.01.3515, 532.43 KB (545,208 bytes), 12/31/1979 10:00 PM)
SMBIOS Version 2.3
Status OK
Status OK
Status OK
Status OK
IRQ Channel IRQ 17
geposted Sat 21 Apr 07 @ 2:12 am
sounds like a latency issue to me, are the usb ports running @ max speed? (sometimes configurable in BIOS)
if not- may need a chipset update.
More memory of course will help! :)
geposted Tue 01 May 07 @ 1:49 am
There is your problem, add more Ram, at least 512 or 1Gb in total should be nice and not expensive, Ram modules are cheap these days, I know because I sell them :)
Upgrade your ram and Fix your swap file on 1Gb, both same values, start and end.
geposted Tue 01 May 07 @ 2:40 pm
Yeah that should do it. My HP is over 4 years old, and upgrading the ram to 1gb was the best $130 I ever spent on the machine. Never had a problem since.
geposted Tue 01 May 07 @ 5:47 pm
Yeah it sure was RAM bought 2 gigs just to be safe/better latency and not cutting out, but wish it was more on point...
Thanks for the help.
geposted Sat 12 May 07 @ 9:27 pm
Glad you sorted it out ;)
geposted Mon 14 May 07 @ 12:37 pm
