Question for you all, support is not responding....grrrrrrrr.
I've been messing around with the demo a bit, but find the audio input restricted to the system microphone instead of a line in.
Audio is not clear and clouded with room noise.
Does the full version allow for this, for is there another way not available with the demo.
Thanks
Thanks
geposted Sun 22 Apr 07 @ 8:51 pm
Try "CamStudio"
geposted Sun 22 Apr 07 @ 8:52 pm
in the full version you can record "what u hear" or select input such as line in or mic (or what ever your soundcard allow).
note: if you're not using vista ,then you won't be able to use the latest version of fraps( you'll need an older version.
I found that out the hard way; heheh
btw : camtasia studio is alright .. i like it for snapshots versus the capturing ( but thats imo)
good luck rick...hope this helps
geposted Mon 23 Apr 07 @ 12:26 am
FRAPS is what we used to record the VT demo we created and I posted a thread about last week: http://www.virtualdj.com/forums/69040/General_Discussion/Visual_Turntablism_with_Atomix_VirtualDJ_ft__Icy_Ice.html
- VT ConQuest
(Visual Turntablist)
- VT ConQuest
geposted Mon 23 Apr 07 @ 10:39 am
