Excuse me for sounding a bit thick, i have been trying out virtual dj on my mates system and love it, he uses version 3.4, i am going to buy virtual dj this week but i have a question if i buy a copy of 4.2 will i still be able to use the skin of 3.4 default as i like the look of it, and its easy to use 4.2 looked complicated for me 3 screens etc, if i have to buy the 3.4 version then so be it thanks
geposted Mon 23 Apr 07 @ 12:15 pm
Once you buy the VirtualDJ Pro ver4.3 you will have access to the skins download section. There is a version 3.4 Default skin made for the version 4 features. So, if that is the skin you like then Yes you will be able to use that look. Also, there is a Basic Audio skin that comes as part of version 4 and you have alot of other skins to choose from.
Look forward to seeing you as a member.
geposted Mon 23 Apr 07 @ 12:38 pm
Thank you for your promt & helpfull reply cstoll,
geposted Tue 24 Apr 07 @ 1:07 am
