Forum: Old versions
Topic: unable to hear cue song loud enough on headphones
I am unable to hear the cue song loud enough on my headphones when my loudspeakers are at performance level.
This is screenshot of of my settings.
geposted Mon 23 Apr 07 @ 7:06 pm
Thats dependent on your soundcard most of all. Does it have volume sliders or even gain ? look in soundcards control setting.
Also, make sure you run VDJ at "always zero" for auto gain setting
I am running a lexicon lambda soundcard. The only time I get a loud enough sound from the headphone is when I plug the headphone straight from my macbook soundcard.
exactly.
So you need to turn up the volume/gain on the other soundcard.
Look in the souncard control pannel, should be volume sliders there
