Hi folks,
If you get the "directx" error when installing the MK2 on Vista, do the following:
1. install VDJ 4.3
2. download "2007_CMK2_2.exe" from Hercules.com and save it to your Desktop
3. click with the RIGHT mouse button on this file on your desktop and select "Run as administrator"
4. follow the installation and reboot the computer
5. now go to
C:Program FilesHerculesAudioDJ Console SeriesMk2updater
and run "HDJ2Updater.exe" to update the firmware. follow the on screen instructions.
6. now you can run C:Program FilesHerculesAudioDJ Console SeriesMk2HDJ2CPL.exe if you want (this is the Hercules Control Panel)
7. Start Virtual DJ and go to "Config"
8. Select the tab "Sound Setup" and choose DJ Console MK2 at the "Sound Card(s)" section. Set the 'Output Channels:' to Master 1&2 and Headphones 3&4
9. Go to the "Performances" tab and set the 'Latency' to "Auto" and DISABLE the 'Safe Mode'.
10. Click on OK
11. load a song to the deck and just push play. Voilà !
NOTE: Vista ALREADY have "DirectX" installed, and it is version 10, that is, the latest one!
1. install VDJ 4.3
5. now go to
10. Click on OK
geposted Tue 24 Apr 07 @ 5:33 pm
