Should I use the
ASUS onboard Audio
http://www.asus.com/products4.aspx?modelmenu=2&model=1178&l1=3&l2=11&l3=307
ADI® 8-channel High Definition Audio CODEC
- Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
- Coaxial / Optical S/PDIF out ports at back I/O
- ASUS Noise Filter
OR
USB Sound Blaster Live! 24-bit External
http://www.soundblaster.com/products/product.asp?category=1&subcategory=206&product=10702&nav=2
24-bit Digital-to-Analog conversion during playback in 16 or 24 bit with sampling rates of up to 48kHz in 5.1 mode and up to 96kHz in stereo mode. 24-bit Analog-to-Digital conversion during recording in 16 or 24 bit with sampling rates up to 96kHz SPDIF (Sony/Philips Digital Interface) out with up to 24-bit at 96 kHz quality. Supports Windows XP SP2.
ASUS onboard Audio
- ASUS Noise Filter
OR
geposted Fri 27 Apr 07 @ 1:41 am
I use the ASUS sound on my MOBO - sound is comparable to the soundblaster.
geposted Fri 27 Apr 07 @ 1:44 am
When you say,
“sound is comparable to the SoundBlaster”
The same as, a little better, almost as good..?????
thanks
thanks
geposted Fri 27 Apr 07 @ 2:20 am
same to moderatly better.
geposted Fri 27 Apr 07 @ 11:00 am
I think Sound Blaster has better dynamics than any integrated sound chip except for Sound Storm by Nvidia.
geposted Sat 28 Apr 07 @ 3:56 am
Actually when It comes to Onboard sound in the last year or so with vista and Analogue systems Sound Max codec VS soundblaster, You could debate for hours which is better.
Truth be told Neither is what I would call "high end".
But in terms of sounding "nice" and "good". Both are about the same. Both work for 6.1 sound etc.
I use intergrated sound because It's just easier. - no extra bits of hardware to worry about.
Kinda like which pick-up is better;
Ford, Dodge, or Chevy, or Toyota.
Take your pick, all about the same anyway.
geposted Sat 28 Apr 07 @ 1:20 pm
