Forum: Old versions
Topic: another shortcut question
seeing that the playlist cannot or does not load song after song in each deck except when in "Automix" mode,can I create a shortcut to load the next song in the playlist into ANY deck?To further explain,let's say I start up VDJ,put in a playlist,load a song in Deck A and one in Deck B,start playing left deck then "Automix" into right deck,that now leaves left deck empty or with the last song that was played,what I would like to do now is to create a shortcut key that will load the next song in order in the playlist into the deck a and then deck B and so on,is this possible?
geposted Fri 17 Sep 04 @ 1:06 am
I don't know wether this can be done or not, but I don't think it is possible, by looking at the actions available in the "playlist" subsection...
macourteau
I wanted to get away from having to "manually" load song after song,that's why I was asking of this.I can't use the "Automix" mode because then I won't get the songs to autobeatmatch.
