Having a problem with internal database corrupted.Did a search but i dont even no where to start.If someone could give my a step by step guide to fix this problem it would be cool.tnx
geposted Sun 29 Apr 07 @ 8:19 pm
You can try this tool , but I am not sure if you can download it since you are Home user.
geposted Sun 29 Apr 07 @ 8:42 pm
In case you are not able to dnld the tool;
If you have a backup of the 2 databases [saved somewhere other than the system you are having problems], You can delete the databases from VDJ and then copy & paste the backup ones.
Hopefully this will work.
geposted Mon 30 Apr 07 @ 7:23 pm
go to c:/programfiles/virtualdj
and look for virtualdjdatabase.xml
and edit it in note pad
they should look like this
<Song FileName="10 The Ultimate [Original Version].mp3" File Size="11993410" Tag Date="701160438">
<Display Author="KrisSy; Trixta" Title="The Ultimate [Original Version]" Tag Read="1" />
<Infos SongLength="16540416" />
<BPM Bpm="17640" Phase="2352" />
<FAME Is Scanned="1" Volume="8324" />
<Atomix Mix Type="3" Tempostat="1131312" Tempo End="15807792" Cut Start="1131616" CutEnd="16336704" Fade Start="1004544" FadeEnd="16356864" />
</Song>
Notice </song> at the end it is like that some songs near the end dont have this and have corrupted the sheet below them add this tag if it is missing , and this should remedy problems.
</Song>
geposted Mon 30 Apr 07 @ 10:40 pm
I can help you avoid this in the future - re DJ-ALF's post above.
If you want to send me and email click on my name at the left and get my email from my blog.
cstoll
cstoll
geposted Tue 01 May 07 @ 12:52 am
i triad to e mail you cstoll but your email wasnt working.
geposted Wed 02 May 07 @ 4:59 pm
Did you follow the instructions? Remove the NOSPAM?
http://www.virtualdj.com/blog/cstoll/blog1003.html
My email works just fine.
geposted Thu 03 May 07 @ 1:08 am
