my mk2 is out of control!!!
1.when i start virtual dj on the screen the volumes on the 2 decks are not in the same place as on the mk2(the crossfader is ok)
2.when i press the efect butons some times dosent work at all and if it does work it wont turn off
3.on headphone selection if i put it on split it dosent work about 75% of the time
4.the volume controls are very slow to react when i spin the wheels on my mk2 it jumps about on the tune for about 5 seconds.
5.if i change the trebble/medium/bass during mixing it skips a beat
I think you will agree with the 5 points above mixing is inposible which i am pissed of about because i have promised people mixes, one of them being my brother who is the army and set of for Iraq yesterday.
the problem started when i instaled updates for virtual dj i have allready uninstaled & reinstaled both virtual dj & the mk2 and is still f**cked.
geposted Mon 30 Apr 07 @ 1:45 pm
which version of the program do you use
try reinstalling the console drivers.
geposted Mon 30 Apr 07 @ 10:22 pm
reinstalled drivers & still dosent work as it should.
im using vdj 3.4
geposted Tue 01 May 07 @ 10:27 am
have you tried the very latest drivers needed to run 3.4 from the hercules website?
geposted Tue 01 May 07 @ 10:38 am
Hercules DJ Console Series - 2.CMK2.2007 package yeah i downloaded this and still dosent work!
thanks for trying to help. It has to be a software problem because the problem started when i instaled updates.But I have reistaled using the disc & downloading updates for virtual dj & hercules dj console. Dont think theres any thing else i can do is there?
geposted Tue 01 May 07 @ 12:39 pm
what is your system spec?
geposted Tue 01 May 07 @ 1:36 pm
Maybe it is problem with your machine, if you can, try on clean OS or on other PC. If the problem persist, you should contact Hercules support.
geposted Tue 01 May 07 @ 2:35 pm
Here are my thoughts.
1. This is normal. Only the crossfader is in realtime. The software won't actually know where the volume or eq knobs are before you use them. I always move every knob and slider, including the headphone selector, through their full range before using. Only takes a few seconds.
3. I never did figure out how to make the split feature work all the time. I used that feature with vinyl all the time but I am glad the MKII took this away from me. I think I get more of a listener's perspective with one ear always open to the speaker output.
2,4,5. This probably all has to do with performance settings being changed. Happened to me, and I had to go back and redo all the tweaks to get it going again.
Hope you get it going!
geposted Wed 02 May 07 @ 1:04 am
how do i change performance settings?
geposted Thu 10 May 07 @ 2:09 pm
If you are using version 3 (home) than you don't have performance in your settings. You should increase latency for your sound card.
geposted Thu 10 May 07 @ 4:46 pm
How do i do that!
geposted Thu 10 May 07 @ 4:55 pm
Damn, I didn't saw version 3 from August 2006, will install it tomorrow and try to help ya.
geposted Fri 11 May 07 @ 1:19 am
how many pcs are you allowed to install virtual dj on?
geposted Fri 11 May 07 @ 9:56 pm
2
EULA SUMMARY:
- This license gives you the right to install and use the software on a maximum of two computers, by one person.
- It does not give you the right to rent or sell computer systems on which the software is installed, or to rent or sell the software or part of it.
- The software is distributed "as-is" and no warranty of any kind is expressed.
- Atomix Productions and its suppliers retain all intellectual property rights in the software.
EULA SUMMARY:
geposted Fri 11 May 07 @ 10:00 pm
So if i put it on my Dads computer to see if it works on that and find i need to buy a new computer i wont be able to install it on the new computer?
geposted Sat 12 May 07 @ 11:52 am
No, you can install it on 2 computers at the same time and only you can use it.
geposted Sat 12 May 07 @ 5:20 pm
Also if u considered to buy a new pc... uninstalled the programme first from ur dad pc.. and then u can have the rights..to install on the new PC. JUST remember it only on 2 PC and only u can use it. I use one on my desktop n the other on laptop.
geposted Sun 13 May 07 @ 11:45 am
Thanks for the help. Will be a while before i can afford a new computer though!
geposted Wed 16 May 07 @ 12:27 am
sorry to be the killer of the party
but i think the console software has a different licence for one pc only
check in the back of the manual please
geposted Wed 16 May 07 @ 11:02 am
