ok my set up is a P4, 256MB ram & 60GB HD plus win XP Home.
upon installing the demo i get up to the big VDJ screen and Trial Version spalsh, then ..... it goes horribly wrong!!
the task bar at the bottom here says vdj is open in its own screen and even task manager says the program is running but it just doesnt open up. when i close the program down it comes up with an error saying invalid instruction - read error and loadsa numbers. =\
any ideas??
sorry if this has been covered elsewhere
cheers
any ideas??
cheers
geposted Tue 08 Jul 03 @ 9:28 pm
Helped user in chat
For all others who this happens to please select appropriate skin for your screen res when installing. If you are capable of 1024 then select advanced, if you are only capable of 800 then select simple skin.
geposted Tue 08 Jul 03 @ 10:16 pm
big shout out to all chat room massive .. another problem solved .. program kicks ass!!!
geposted Tue 08 Jul 03 @ 10:23 pm
Thxs ;)
geposted Tue 08 Jul 03 @ 10:34 pm
