K, so i'm almost done building my mega machine, I just need an audio card and a video card. My question is this though.....
On the back there is 2 dvis, and an s-video. If I got this card, would I have to get another card for my vdj display, and then just use that card as a s-video out, or can I do an extended desktop on that ONE card, and have the output of the video mix come out of the s-video, while my main dvi is running my display????
geposted Tue 01 May 07 @ 10:48 pm
You will have your DVI going to your display, where you will see the program. You will then use either the other DVI or s-video, to your projector or other display. This card will do what you want. Just remember the other DVI and s-video is a "one or the other" thing.
geposted Tue 01 May 07 @ 10:58 pm
Yea, thats fine, i mean I only need one screen to see the program.
Thanx for the quick responce!!
geposted Tue 01 May 07 @ 11:03 pm
