i can´t install hercules MK2, i can´t open the virtual dj (dj console) give me an erro, it said that i not connect the USB of hercules MK2, grrrrrrrr
any help ?
any help ?
geposted Wed 02 May 07 @ 10:15 pm
Did you check to see if the usb port you are using supplies enough power? I have one powered and two passive ports on my computer, get the same errors if I use the wrong one.
geposted Wed 02 May 07 @ 11:02 pm
any help ?
any help ?
What OS version are you running? If Vista, follow directions http://www.virtualdj.com/forums/66806/General_Discussion/DJConsole_MK2_MP3_-_Vista_update.html?page=2
new drivers for vista:
ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_2.exe
if XP: uninstall software including MK2 and do a reinstall. One of the drivers probably did not install correctly. I had the same problem at first.
geposted Thu 03 May 07 @ 12:13 am
