Topic: can't get it to stop
When i browse through my folders in vdj, I usually hit the artist tab so they'll be in order by abc. If I leave that folder & then come back to it later.......I have to hit the tab again. Is there a way to make vdj remember & leave it the way I had it? Its just an extra step that doesn't need to be taken.
geposted Fri 04 May 07 @ 8:39 pm
nah no luck. interesting tool though. Any other ideas?
You can use registry tweak but make a backup before this:
re order column headers (change sort order)
1) open regedit
2) go to HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ
3) edit the AutoSort key
0 is the default. Another value will change the column used to sort.
note:
Value 1 = Sort by Title
Value 2 = Sort by Author
Value 3 = Sort by BPM
It was posted by someone long time ago.
Hope this helps!
hell yeah. it would be a nice addition though to make vdj remember.
thanks alf, this will work
problem.....I don't see a autosort key to edit. do I make a new one or what??
It's actually in HKEY CURRENT USER -- Software -- VDJ
Yes, it is in the Current user, this was for version 3, my bad :)
There is Autosort key, just checked.
does it matter if its hex or decimal. I tried both.& restarted but no haps. is it only this key that has to be edited?
Hm, not sure, will try later and let ya know, I am in a hurry, have a gig tonite :)
