i want to get the two time coded cd's for cue. numark told me that i have to use there sound card for it to work is this true? will my maya usb 44 sound card work i want to hook it up to my numark cdn 88 cd player.
geposted Fri 04 May 07 @ 10:13 pm
Yes it will work, cue is the same as vdj, to my knowledge they havent made it stricktly to where you have to buy numarks sound card. Just go to downloads and download the vdj timecoded cds
geposted Fri 04 May 07 @ 11:23 pm
they are the same just numark trying to sell you a box hehe :)
geposted Fri 04 May 07 @ 11:27 pm
I downloaded the time coded track. do i copy only 1 track on each cd?
geposted Fri 04 May 07 @ 11:53 pm
yes burn the file as an audio disk one mp3 per disk
geposted Fri 04 May 07 @ 11:54 pm
Will the Maya also support Time Coded vinyl? I'm thinking about making the jump, but don't want to have to buy a Serrato box or an MK2.
geposted Fri 04 May 07 @ 11:56 pm
yes. if it works with vdj it works with numark
geposted Fri 04 May 07 @ 11:57 pm
i'm trying to set it up when i check asio setup under sound setup it says error
geposted Sat 05 May 07 @ 12:13 am
cue is picking up my maya44 when i'm playing without cd's. but its not letting me pick asio mode when i'm trying to set up my cd player that field is blank. comon guys help me out i want to get this thing up & running
geposted Sat 05 May 07 @ 12:50 am
did the time code vinyl of virtual dj work with numark cue?
the virtual vinyl is very expensive
geposted Sat 05 May 07 @ 6:10 pm
yes
in the usa vdj tcv is gen 3 which is the same as numark vv
in europe last gen 2 ones are being sold then gen 3 will be released
gen 3 adds a few new features
geposted Sat 05 May 07 @ 6:18 pm
which error?
geposted Sat 05 May 07 @ 6:30 pm
SOUNDCARD ERROR
geposted Sun 06 May 07 @ 9:43 am
my maya 44 is not showing up under asio in the sound setup when i'm trying to set it up to use my cd players . but it works when i play just using the laptop alone.
geposted Sun 06 May 07 @ 9:12 pm
