on hideous XP media center edition ?? anyone currently doing that ?? my d: recovery drive is very crowded only 2% free .......it was like that str8 outta the box too .....
i have deleted all restore points but 1 ...... i seemed to be blocked , can not view the contents of the partition ???
anywhoo i wanna resize it w/o wiping the main drive ......
at there website it says xp pro (which is basically what mce is) but it doesn't say specifically it is compatible w/ mce .........
to reiterate, i want to increase the size of the d: recovery drive in XP media center edition , preferably without too much pain in the tookus, can i use partition magic ??
geposted Sat 05 May 07 @ 3:53 pm
Probably yes, but you need more free space for that and I don't suggest it because it is a risk, you can lose all your data. It is better to make partitions on a clean drive.
geposted Sat 05 May 07 @ 5:30 pm
