Hi,
This is all new to me. Been mixing at home with 1210mk2 and small clubs for about 12 years. Just loaded up the software and learning to use it. My question can you listen to the 2 tracks that you are going to mix in headphones before you mix them, like getting the timing right using turntables and mixer and preveiw what the mix is going to sound like.
cheers
cheers
geposted Tue 08 May 07 @ 12:30 am
Shure you can and many more that can't be done with TT's. You can also get Timecoded Vinyls and use what U are use too to controll Virtual Dj. Check out Timecode vinyl demonstration by DJ GetDown:
http://www.virtualdj.com/download/virtualdj_by_dj_getdown.wmv
Take a look at hardware supported:
http://www.virtualdj.com/products/hardware.html
geposted Tue 08 May 07 @ 10:01 am
