I had to do a fresh install of VDJ & Vista.
I backed up the VDJ folder before this. I thought it had everything in it, but on restoring it back to it original location i've lost info.
Is some of the info (BPM's etc) saved elsewhere?
Gary
Gary
geposted Wed 09 May 07 @ 1:48 am
Read this thread - specifically my posts --
http://www.virtualdj.com/forums/65871/PC_Version_Technical_Support/Vdj_Database.html?highlight=vista%20database
geposted Wed 09 May 07 @ 3:19 am
Thanks mate,
Oh how i miss the day when things you purchased came with instructions. I didn't save the right bit then, so i have 20000 files to analyse before tomorrow evening.
Best i get started.
Gary
Best i get started.
Gary
geposted Wed 09 May 07 @ 2:39 pm
I found the file and i have all my bpms back,. Everything is fine, except everytime i click on local database, its empty and asks me if i want to rescan my drives.
I imagine there is another file i haven't copied across or haven't copied into the right place. Does anyone know what its called?
Gary
Gary
geposted Wed 09 May 07 @ 9:09 pm
scan the drive but untick calculate bpms
geposted Wed 09 May 07 @ 9:19 pm
Yep, done that. Everytime i restart the program i have to do it again. I never used to have too.
Gary
Gary
geposted Wed 09 May 07 @ 9:23 pm
The other file is the mp3database.txt -- same thing as with the XML you want to save that file in the hidden user folder mentioned in the other post.
geposted Wed 09 May 07 @ 11:40 pm
