Forum: VirtualDJ Skins
Topic: Skin MultiFunctions
Hello!
A new upgrade of my skin is availaible here: http://www.virtualdj.com/addons/skin.html?id=2448
This is already a very appreciated skin on the French Forum!
Description:
This skin use the "Internal Mixer" and "FullVideo" skins...
  • V1.3
    [list]
  • -6 CUEs added for each deck
  • -Equalizer's faders added
  • -REVERSE function added
  • V1.2
    • -UNLOAD function added.
    • -Crossfader curve can be selected directly from the skin!
    • -some visuals added.
  • V1.1
    • -Scrolling can be disabled for professional use.
    • -Video output can be activate/unactivate from the skin!
  • V1.0
    • -Mixer and video pannels on the same skin!
    • -Full title, author, bpm, pitch, elapsed time, remaining time.
    • -SYNC and MAGIC BEATMATCH on the same skin!
    • -Brand new fonction LOCK. You can disable the software control by mouse (for private parties when everybody can enter the Dj's area;p). To take the control back, just click on my e-mail adress)
    [/list]
    Give me your opinion!
    SQ;p
    geposted Wed 09 May 07 @ 3:00 am
    Love the skin, have loved it since ver 1 - even made a mod of it for the club I am at.
    Some notes -
    1. On the right deck the first CUE box is labeled 2 and not 1 -- look at your 6 cues for the right deck.
    2. Could you add the DISABLED crossfader as one of the crossfader choices?
    Other than that, I think I will mod this one for my needs at the club and use it!!!! Thanks!
    cstoll
    great job.
    Bug: On the right deck the sample selection doesn't work, if i click on the down arrow I can't see the list.
    New: Please add all the 6 crossfaders curve
    Hi!
    I've repaired the CUE label and the sample selection problem...
    I will uprade a new version with these changes later... I want to add the crossfaders curves and "NO CROSSFADER" like you ask me ;p
    I will tell you when the uprade will be online...
    SQ:p
    Hey!
    A new upgrade of my skin is available!
    You can download it from here: http://www.virtualdj.com/addons/skin.us.html?id=2448
    Features:
    • V1.4
      [list]
    • -Crossfader's curves "NO CROSSFADER" and "USER DEFINED" added
    • -EQ faders are now biggers
    • -Pitch reset button are now biggers
    • -The sample selection from the deck 2's list bug si now fixed!
    • -Visuals bugs when using Timecodes or Cues are now fixed
  • V1.3
  • V1.2
    • -Some visuals added.
  • V1.1
  • V1.0
    • -Brand new fonction LOCK. You can disable the software control by mouse (for private parties when everybody can enter the Dj's area;p. To take the control back, just click on my e-mail adress)
    [/list]
    /!\: Users who have download this upgrade between June 8 and June 10 must download it again to fix a little visual bug ;)
    I'm still waiting for your suggestions!
    SQ;p
    (Thanks to the 8781 downloads!)
    Thanks squatman, I will test :)
    If i download the file i must rename it from . zip to .exe to get it to work to install it . mayby some one can fix that .
    solved was a bad installer:)
    Hey!
    Features:
    • V1.5
      [list]
    • -Function "CLONE DESK" for beat juggle added!
    • -Master volume on the mixer
    • -Display the use of the CPU in percentages too
    • -Brand new function "CPU SAVER" To decrease radically the use of the CPU when yo need it! (by desactivate some visuals which use a lot of CPU - Scrolling, Songpos, Rotation...) Click on the green button (next to the CPU's status bar) to active it!
  • V1.4
  • V1.3
  • V1.2
  • V1.1
  • V1.0
    [/list]
    SQ;p
    The skin is great! I use it for all my live shows. I'm guessing it would be very difficult to make a version that would allow for more tracks on the screen...but other than that, it's great!
    Sorry guys, the bad installer is my fault. I forgot to rename the file. Anyway it's fixed now!
    stuff happens my friend dont worry about it
    谢谢
    why can't download?
    dianzifashaoyou wrote :
    谢谢
    why can't download?
    Your not a professional registered user, or any level user.....Hope you join us soon....
