I Have Itunes, the last release with quicktime included, I have instaled 3ivx, and I have a decent videocard, 9800 Pro, and two monitors, one 16:10 and another CRT 17 inches.
I can´t see my video with mov extension, I´m trying this software to buy it, but I can´t see the images of the files I like to watch videos, what can I do, could you help me please.
what I´ve done is, change my configuration using diferent codecs, when I use video decoder, not function, when I use quicktime audio decoder, only can hear audio, so what can I do.
thank you for your help
geposted Wed 09 May 07 @ 3:22 am
If they are iTunes DRM protected then you will not be able to view them. You can't use an audio decoder for video. You need to use the built-in VDJ video decoder or the Windows MediaPlayer Video Decoder. Are you able to watch the .mov files in Windows Media Player?
geposted Wed 09 May 07 @ 3:28 am
"Thank You" for your answer
Yes, I know that I can´t use any audio decoder to see videos I just wanted to point the fact.
Well, right now, I have installed my new XP64 and I´m going to reinstall al my software again, so when I´ve done this, I´m going to verify this solution, and then I will post again to tell you what happened.
And again "Thank You" for your answer
geposted Wed 09 May 07 @ 11:17 pm
