Hi
My cpu jumped to 100% last night at work after
about 3Hrs of play \.Can someone please tell me
how to solve this prob.It has happen couple times in the past.
My laptop is fine! this only happens with vdj running.
When this happen i was playing a 30 min mix i made previously
geposted Sun 19 Sep 04 @ 11:43 pm
This may help you in VDJ setup max load put it to none big mp3 or cd's can do this.
geposted Mon 20 Sep 04 @ 5:09 am
No, if you use memory limitation (and I think it is with your 30 min song) your CPU will work at 100% all the time.
If you put this limitation on NONE, your CPU will allway work at 100% (with all songs).
It is not a problem, it is just another working mode of VDJ to reduce memory needs on long tracks.
geposted Mon 20 Sep 04 @ 6:26 am
