VDJ does not work with the ttm57 but it works with the sl1 box. Are there any plans to make it work with the ttm57 in the near future?
geposted Thu 10 May 07 @ 8:21 pm
Rane has prevented that mixer from working with other DJ software
So it cant work with VDJ, unless some sort of "hack" is applied
geposted Thu 10 May 07 @ 8:35 pm
even though that the drivers for it are public?
anyone have the hack? ha
geposted Thu 10 May 07 @ 8:50 pm
Tell Simon to hack it LOL :))
geposted Fri 11 May 07 @ 1:05 am
We need someone to come up with a "crossfader start to MIDI converter" so we can use the crossfader to control vertual dj and not have to go out and buy a $1000 mixer just because it has midi.
geposted Fri 11 May 07 @ 8:43 am
Is that possible to do that KregCZ? to make a crossfader start to midi converter and use a regular mixer?
geposted Tue 15 May 07 @ 4:48 pm
technically, as long as it has a variable voltage (volume) difference over the crossfader (unlike digital faders), then it should be possible. Different voltages could be converted into a MIDI crossfader position
geposted Tue 15 May 07 @ 6:30 pm
its probaly in the firmware , some where to simply drop the usb connection on other softwares
geposted Tue 15 May 07 @ 10:56 pm
I would think that you could take the fader start siginal run it to a some small device that would sence the signal and convert it to midi.
Midi's been around about 20 years, I think someone could be smart enough to do it.
If someone can convert a usb game joystick to a midi controler, then someone should be able to convert this simple signal from the fader start.
geposted Wed 16 May 07 @ 5:08 am
