I don't have an ASIO soundcard yet, but can still use the TCV’s with the 3 soundcards I have? I have VDJ 4.3, AMD Athlon 64 3700+ 2.20GHz Soundblaster live 5.1, Realtek AC'97 & Creative Soundblaster and am using GEMINI TT02 Turntables and GEMINI PS-04 mixer. I quite don't understand how to configure the ASIO driver to use TCV with the equipment I have. Is there something I need to do to the 3 soundcards or the ASIO config page? I have read through the forums for days and I’m just not understanding how to get it going. Maybe some sort of diagram would help me….ANY help would be gladly appreciated
geposted Sun 13 May 07 @ 3:58 am
Try in Blog section, I don't use TCV's.
http://www.virtualdj.com/blog/
geposted Mon 14 May 07 @ 11:22 am
try www.asio4all.com
for the all card asio driver
you can use this to make one asio card out of many basic cards
geposted Mon 14 May 07 @ 11:42 am
forgot to say I do have ASIO4ALL & I'm not sure how to configure it to the soundcards I have to make TCV work.
geposted Tue 15 May 07 @ 1:28 am
for you INPUTS, select 2 channels from any combination of soundcards, and enable them. DISABLE every other 'in' channels you may see on the rest of the cards.
for example, you could have 2 sound cards, each with 1 stereo input. Then you enable each card's input, and disable any other input you may see of other soundcards
geposted Tue 15 May 07 @ 6:34 pm
