Forum: Old versions
Topic: scanning songs
Hi, actually I bought vdj yesterday but only today I started to experiment it and while I was doin it, scanning hd for .mp3 files a window appeared "A fatal error occured. VirtualDJ can try to automatically recover from the crash. Just click on the recover and everything should be fine.After clicking in the recover button VDJ is closed and I get back to windows.
For me is essencial that this is solved because I have all of my mp3 in My Documents folder and without that files I only can mix the files that are in the work environment.
Please answer me about how to solve this.
Thanks
geposted Tue 21 Sep 04 @ 3:05 pm
Hi, actually your problems could be caused by a number of reasons. However, I would suspect that your cracked version 2.01 of the software could be a big part of the problems that you are having. I'd recommend that you first completely uninstall this outdated problematic cracked version of the software that you are using, and then buy it and see if the problems are now gone.
