Hi,
Can someone please help me with this! If I have deck 1 selected in VDJ (as in all buttons on keybord such as play an stop etc. correspond to that deck) and I move the jog wheel on deck 2, all the controls switch to deck 2! How do I stop that happening?! Its SOOOO anoying!
Thanks,
Rory.
Thanks,
Rory.
geposted Tue 15 May 07 @ 8:48 pm
Hit the tab button which is the same thing as headphone cueing. You will see either the headphone light switch over or the LED over the dec switch. depending the version used... or you can go in to config and find the hotkey button and change the response to a particular channel. The only thing will be that you have more buttons to remember.
geposted Tue 15 May 07 @ 9:15 pm
Hi,
I know you can just it tab to switch it over but I want it to stop switching over when the jog wheel is moved! But thanks anyways!
Does anyone know how to do this?! I really need to know ASAP!
Thanks Guys,
Rory!
Thanks Guys,
Rory!
geposted Wed 16 May 07 @ 1:26 pm
Anybody?!
geposted Wed 16 May 07 @ 4:26 pm
change auto headphones to disabled
geposted Wed 16 May 07 @ 4:28 pm
I LOVE YOU DJ CYDER!!! Thanks man! Thats made my day!! It's been anoying me for ages!!
Rory!
Rory!
geposted Wed 16 May 07 @ 7:28 pm
