Dear People,
Can anybody tell me:-
1. What is the best file format to use i.e wav, midi or MP3 etc with the virtual dj software ?
2. Which formats give best quality and performance ?
3. Can anyone recommend any software that you can use to clean up, re-code, alter the temp /pitch of mp3 files.
Would be very grateful for some advice
Cheers
JAY
Cheers
JAY
geposted Wed 16 May 07 @ 8:24 pm
The best format for ANY software is WAVE, sampled at 44.1KHz, 16bit stereo. This is very fast to be loaded, with CD quality (or better!) but... it's very BIG!
Anyway, if you own a large Hard Disk, you can store WAVE files without major problems...
geposted Wed 16 May 07 @ 10:57 pm
nice 1 thanks alot
geposted Thu 17 May 07 @ 3:01 am
