I'd like that VirtualDJ could be connected to the phono inputs of a mixer without the need of the Inverse RIAA plugin, just that you could already pick in the soundcard setup and allow phono and line outputs, it's not the first time I have to connect VirtualDJ to a phono input and use the Inverse RIAA plugin (which resets everytime I load a new song and eats system resources)
Thanks.
Thanks.
geposted Sat 19 May 07 @ 5:00 am
That's not a bad Idea. I've used the inverse riaa plugin as well and had the same issue - I eventually just dropped it.
Good idea though
Good idea though
geposted Sat 19 May 07 @ 7:07 pm
Yea, it's a bit annoying, hope somebody else wants this too :)
The plugin does it's job but I think it should be integrated on VDJ
Thanks.
Thanks.
geposted Sat 19 May 07 @ 9:02 pm
Ohhhh please I been waiting for this function to be integrated on VDJ I hope that VDJ team make it happen ass soon as possible, hopefully for the next updated..
Dj_johan
Dj_johan
geposted Mon 21 May 07 @ 6:55 pm
Yeah, good idea!
For now though, I think there's a registry option you can change to keep effects on even when you change the song.
Try the registry editor plugin if anybody fancies having a go (might be wrong though, can't get to VDJ at the mo to check).
geposted Mon 21 May 07 @ 11:24 pm
