Quick Question:
If I upgrade to a new computer and install Virtual DJ on my new computer, but still use the same external hard drive (music storage) I was using before with my old computer, how do I get the data I entered under Virtual DJ on my old computer to my new computer (i.e. BPMs, filenames, etc)? ...things I manually entered...
Thx!
DJ Pitufo
Thx!
DJ Pitufo
geposted Sun 27 May 07 @ 7:40 am
Pitufo,
It depends on what version you're using.......What version of VDJ are you using?
also..... you need to put your serial # in your profile so it shows you as a registered user..
you are a registered user right?
geposted Sun 27 May 07 @ 10:04 am
