OK. I downloaded a skin. I think it was a technic skin. I put my serial # in and it downloaded. Then I found it and clicked on it and hit run. It said it was installed, but now nothing has changed its still the same skin .. I must be missing something. If anyone could help I would appreciate the advice.
geposted Tue 29 May 07 @ 4:41 am
Yeah Dmix..go to your config menu and click on the skin tab.. and select the new skin....I hope that helps..
geposted Tue 29 May 07 @ 4:43 am
I tried to open cue up then click on config, but there isn't any new skins
geposted Tue 29 May 07 @ 5:09 am
you need to place the skin here
c:/programfiles/virtualdj/skins
geposted Tue 29 May 07 @ 1:55 pm
NO you need to place the skin here C:/ ProgramFiles/ Numark Cue /skins.
geposted Tue 29 May 07 @ 3:50 pm
I did place my downloads in to the skin folders. I thought it would work, but still the skins are not there. Thats why I started this thread. Because I thought maybe you needed to do something else..
geposted Thu 31 May 07 @ 3:45 am
would you mind trying a another skin and telling me if this works
and could you try and remember which skin it is and i will test the installer
geposted Thu 31 May 07 @ 1:26 pm
