I was going through some pictures of our new house and I think I captured a picture of someone looking back at me. Check the picture below tell me if you are seeing what I'm seeing.
geposted Tue 29 May 07 @ 2:00 pm
The face on the wall?
P
P
geposted Tue 29 May 07 @ 2:10 pm
Think you've been watching too much X-Files, looks like a normal photo to me :)
geposted Tue 29 May 07 @ 2:13 pm
Ok then I'll just ignore the floating orb above the deck and the face on the deck rail ;)
geposted Tue 29 May 07 @ 2:14 pm
Where? Can you describe better please?
is it beside the wooden chair far left at the background? a little girl??
That house next door is totally empty btw
geposted Tue 29 May 07 @ 2:16 pm
sounds like the pcdj spies have found you
geposted Tue 29 May 07 @ 2:28 pm
its the anti christ - dj style....
geposted Tue 29 May 07 @ 2:34 pm
Could you circle where the face is supposed to be I cant see anything unusual about the deck at all.
geposted Tue 29 May 07 @ 4:14 pm
Hi Cyder
I have enlarged & brightened, still see no faces... sorry
geposted Tue 29 May 07 @ 4:44 pm
Actually, i do see something!
I zoomed in more and i couldnt believe my eyes....
geposted Tue 29 May 07 @ 4:58 pm
Yeah Cyder, I see what you're talking about. Saw it right away.
Looks like someone (I first thought an asian person because I was seeing a "bowl" haircut - but that's actually just because of the 2 closer and darkened posts criss-crossing eachother - and some cut off shoulders with what I thought was kind of a grey school uniform) looking straight into the camera from between the fence posts.
The "facial definition" is actually just because of the blurred and darkened spaces between the 2 sun-lit posts that can be seen through the darker ones upfront. The cut-off shoulders was just because of, again, the darkened front-most posts and the chairs arm that can be seen through them. The "orbs" are just sun flare in this case.
It's just an optical illusion.
Still gave me a bit of a chill though... =)
- VT ConQuest
(Visual Turntablist)
No THIS was funny!!!
- VT ConQuest
geposted Tue 29 May 07 @ 5:08 pm
I'm seeing something
looks a damn lot like the guy on some other dj software...
hum, scary
hum, scary
geposted Tue 29 May 07 @ 5:19 pm
LOL
"Ok then I'll just ignore the floating orb above the deck"
That's called "the sun".
Okay, okay, you mean the little light thingy above the chair? That could be anything from a weird reflection from the sun, to s spot on the lens to something that was there that you just forgot about. If there was a bright floating object there, I'm pretty sure you would have noticed it in the bright clear of day much more easily than in a old photo.
""Ok then I'll just ignore the floating orb above the deck"
"and the face on the deck rail ;)"
Notice those tiki stick things on the left side fo the deck? (I think they are used to keep mosquitoes away) I think you've got atleast one more, that is sitting line of site behind that post, so that just the top is visible.
Or, maybe aliens were visiting that day... LOL..
geposted Tue 29 May 07 @ 5:20 pm
sorry about the double post on the :
I was doing cut & paste stuff, didn't catch the flaw before posting it. Would fix it if there was an edit feature.
geposted Tue 29 May 07 @ 5:23 pm
Mystery solved... Got the image analyzed by GB Labs Inc
geposted Tue 29 May 07 @ 5:30 pm
very strange things going on here but this is what i saw
geposted Tue 29 May 07 @ 5:38 pm
LMAO>>> NORWAY
geposted Tue 29 May 07 @ 5:43 pm
