Please, please, please can someone tell if it's possible to play standard vinyl with vdj. If so, how is it done? Thanx!
geposted Thu 31 May 07 @ 12:56 am
Yes, you have bypass option so you can play ordinary records in VDJ.
geposted Thu 31 May 07 @ 2:44 pm
There is in fact no bypass option. It basically stank, so they removed it. You have to have some sort of hardware bypass, and trust me, y-splitters are not cutting it (you loose much of the higher frequencies, resulting in a muffled sound). The only real option I would recommend is getting the Virtual Vinyl interface or the SL-1 soundcard from serato. These are powered sound-cards with hardware bypass which allows you to play regular vinyl without even having your computer connected.
geposted Thu 31 May 07 @ 3:39 pm
How do you mean they removed it? I don't use TCV's but I remember it was there? Like a shortcut or on some skin?
geposted Thu 31 May 07 @ 5:44 pm
