Happens you need to play a large file, a mixed session you previously made, it's would be great if VDJ recognized files bases on their size and decided to analize them or not.
Also a "no analyze" button would help in order to prevent VDJ (freezing and crashing) to use all the cpu and ram resouced for that file.
geposted Mon 04 Jun 07 @ 11:13 am
try setting a large file to max load always
in 4.3 it should work fine.
its important for a song to be analyzed or there will be no wavform
and bpm info will not be known neither will gain
geposted Mon 04 Jun 07 @ 12:18 pm
exactly my point : i dont' want wave form because i already know it since i mixed it.
also i dont' care about gain adjustment because it's also fine and for the max load time i want it the minimum as to save resourses.
geposted Mon 04 Jun 07 @ 12:28 pm
