Forum: Old versions
Topic: loop buttons
is it a way tho change the lenght of the loops on the loop buttons
i never use the loops of 1 or 2 beats.
I would like have on the buttons : 4 , 8 and 16 beats.
is it possible ????
geposted Mon 27 Sep 04 @ 5:58 pm
yes
open the xml file of the skin you use.
search for "loop"......you find ....
hm didn't work with copy paste...
but you find button
sorry....they won't put it in the messege...
the "skin caracter" are not allowed in forum... lol ;)
look for the code in xml file regarding loops for that skin, and change the value ;)
or you can also make keyboard shortcuts for the loops you need most ;)
