Forum: Old versions
Topic: Maya usb44 problem asio.
I have this card and i can´t work with the 4 chanels. I have the drivers 2.5 - July 12, 2004. "ERROR ASIO"
My system is xp home servi pack1.
Help me please. ¡
geposted Tue 28 Sep 04 @ 12:26 pm
Sessions, you should search the forum before posting double/same issues.
see https://virtualdj.com/forum/display.html?topic=5241
i have the same troubles with my maya EX (5.1)
i'm not sure what's th cause, or VDJ is not supporting Maya cards in ASIO-mode.
or it's the Maya-card's drivers..
its not just the 44's its also esi cards too ie gigaport,waveterminal, etc. I hope its fixed soon too
I don't know what I did different but mine works fine. I had both the gigaport and maya hooked up. I just ran the ASIO installation program and it was ok. Not the one on the disc with the setup program but the one downloaded from the web site. I hope you guys get this working soon because it really open up worlds in mixing this software with an external board.
did you use the asio drivers from www.usbaudio.com ?
at least i did, and i got only 2 channels working in asio-mode.
Yes. I did. And set the advanced config in the audio menu on VDJ. Then everything worked fine.
