I am looking at numark site and the connections on the back look weird to me.
I guess it is because I use to just hooking up everything to a mixer.
How do you connect this controller?
Thanks in advance
Thanks in advance
geposted Thu 14 Jun 07 @ 11:30 pm
not that i have seen it, but i quess its usb.
geposted Fri 15 Jun 07 @ 12:09 am
Yeah, the DMC2 got USB only. You need to connect your mixer to your soundcard(internal or external) to make it work.
geposted Fri 15 Jun 07 @ 12:23 am
k_one is completely correct. To explain a little: The Dmc2 is a controller only, it does not contain a soundcard like the Hercules DJ console.
So you will need a pc, Dmc2 and a sound card with multiple outputs. You connect the soundcard as you would do without the Dmc2 and then connect the Dmc2 to a free usb port and switch it on in the VDJ config panel.
Ewout
Ewout
geposted Fri 15 Jun 07 @ 10:40 am
and dont forget about jpboggis mapper. one other thing that the dmc has that i was suprized about it has a clamp to hold the wire from the power supply in the back so u dont have to worry about it coming out at the worst times.
geposted Sat 16 Jun 07 @ 8:14 pm
Does the DMC2 works with USB only or need the power supply also?
geposted Tue 24 Jul 07 @ 6:51 pm
It needs its own power supply.
geposted Tue 24 Jul 07 @ 7:04 pm
kk Thanks
geposted Wed 25 Jul 07 @ 1:33 pm
