Hello!
Do anyone know the software Mix-In-Key and can approve of it?
How well dos it work with VDJ?
Regards
Mads Hansen
Regards
Mads Hansen
geposted Fri 22 Jun 07 @ 10:41 pm
It is a huge times time saver. Hopefully someday VDJ will have a 'key' field that shows the tag : ) I went through and added the key in the comments field so I can sort all my tracks that way. New version comes out in August, and like VDJ it is a free upgrade if you buy the current version.
geposted Mon 25 Jun 07 @ 5:17 pm
It works great. I too would love to see it integrated. I added the key to name tag. I didn't think about the comment field at first and it's too late to go back and change. I find you still have to sort by bpm so I can do that first and then look for the songs key. Millsmobile, thanks didn't know a new version was coming out.
geposted Thu 12 Jul 07 @ 9:07 pm
i noticed that the key in the comment field of Mixed In key doesn't translate to the comment field in VDJ. Also, I wish the Mixed In Key program didn't add a hypen, since this is what VDJ apparently uses to separate name and title fields. Other than that, it seems like a nice program. VDJ should definitely integrate it in their already-superb application.
geposted Tue 17 Jul 07 @ 2:32 pm
