Forum: Dutch Forum
Topic: mixen met vdj
wie kan mij vertellen of ik deze mengpaneel kan ge bruiken voor vdj
DXM01 USB DXM01 with 2 USB Connectors
The DXM01 USB is a 24-bit digital DJ mixer with a 10” tabletop design that includes two USB ports for direct computer connectivity. Audio files can be played from computer and mixed along with records, CDs, and microphone. Mixes can also be recorded back to computer via USB. The DXM01 USB works seamlessly with all soundcard-compatible Windows and Mac audio software, and all audio file formats are supported, including MP3, Windows Media, and AIFF files. No software drivers are needed with Windows XP or Mac OS X, and a USB cable is included. With a 24-bit digital signal path throughout, the DXM01 USB offers the purest sound of any DJ mixer, all digital controls, and sub-bass synthesis with intensity control.
_ Dual USB ports
_ Mix audio files directly from computer together with records and CDs
_ Record directly to computer
_ Works with any audio file format
_ Works with all dual sound card compatible Windows and Mac audio software
_ 100% 24-bit digital design
_ >103dB S/N ratio
_ Noise-free digital controls
_ Numark D-Type crossfader
_ All-digital fader
_ Continuous rotary slope control
_ Reverse switch
_ Sub-bass synthesis
_ Intelligent bass enhancement, far superior to EQ
_ Adds sub-bass that harmonically matches the music
geposted Fri 01 Oct 04 @ 1:05 pm
if i were you, i would get an analog mixer with low, mid and treble knobs for each channel.
i would dis-advice you to get a Usb-mixer for 2 reasons:
1) usb has a latency (especially if you use the sliders rapidly)
2) VDJ has no direct USB-mixer support (yet). it might work for the multichannel output, but i don't think you get the sliders on the usb-mixer to correspond to the sliders on VDJ.
i would go for some decent analog quality mixer.
geposted Fri 01 Oct 04 @ 4:17 pm
fuk ik was even vergeten dat dit het dutch gedeelte was ;)
geposted Fri 01 Oct 04 @ 4:19 pm
drokzHome userMember since 2004
ik heb en 4.1 geluidskaart, en je kan virtual dj hier mee instelle dat je heel simpel met een echt mengpaneel kan mixen
moet je maar ff kijken bij configuratie
geposted Sun 24 Oct 04 @ 12:46 am
ja, dat kan.. maar niet met de demo versie.
met de full-version kun je over meerdere kanalen uitsturen en dus een externe mixer gebruiken.
geposted Mon 25 Oct 04 @ 10:15 pm
