Forum: Old versions
Topic: question on using time coded cd
i downloaded the timecode mp3 for using a cd turntable on a
(NUMARK CDX cd turntable)
Q1: after i enable vinyl timecode do i have to mute line in on the sound card so it wont play the timecode tone?
Q2: in the config screen there are pictures of different soundcard setups i am trying the trial version right now.
and can only use the first sound card setup at the top of the config screen. now i plugged in one turntable in on cpu sound card and out to my gemini mixer. is this possible in the trial version or do i need the full version so i can pick the different sound card configurations?
Q2: will Final Scratch Vinyl work for the turntable end of things or do i need the virtual dj vinyl as far as vinyl goes?
geposted Fri 01 Oct 04 @ 10:11 pm
thanks for the replies
Q1. Yes otherwise you'll only hear the TC tone make sure you input is selected as the recording device though
Q2. You need the full version, and by the sounds of what your trying to do you also need an ASIO campatable Soundcard
Q3. you need the VDJ vinyl
